Ga door naar hoofdinhoud
A mid-range smartphone from Samsung released in 2019.
121 Vragen Bekijk alle
My phone always "overheats"
My phone went in to water speaker and charging port down. The phone still works but now it constantly tells me that it overheats even though it's fine, the overheating function stops me from doing anything for a short time. It's been 3 days and it has gotten worse now I can't use music for a while without the notification of it overheating appears and closes all the apps I had on. How do I turn this Notification off?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @katkatapang
Your phone is not waterproof
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes what happens Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Samsung Galaxy A50 repair guide that will help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later, before it fails entirely.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Kat (Katapang) zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 11
Altijd: 28
