Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Vragen Bekijk alle
Vraag afgerond
3GS backlight our after screen repair
I replaced an LCD screen in a 3gs and and the backlight isnt coming on.
The lcd is brand new and I turned the phone off when I replaced the screen to prevent a short.
The phone hasnt been updated in awhile so could a restor fix this?
I tried resetting the phone setting but nothing changed.
The only other thing I can think of is the coil shorted but the phone was off when I worked on it and there is no water damage.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Have you tried a different LCD? It just could be that the one you received is bad. Sounds like you took all the precautions during the fix, so I don't see any other issues besides a bad part.
What happened to the original LCD? If it was showing backlight before, then a new LCD should as well.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 637
