No green in picture
Magenta screen on all external, aerial inputs, no green in picrure
Is dit een goede vraag?
@gary42893 what have you checked. The very first thing you want to do is to use different video inputs. Make sure that you are using Coax and Component inputs as well. Change your HDMI cable if that is what you are using. See if using the different inputs had a different outcome. Next, we would need to see what your display shows you. It is possible that this is a panel issue but most likely it is a failed Gamma IC or a failed main board GPU. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 18
