Ga door naar hoofdinhoud
Beheers multitasking met de Yoga Slim 7 Pro. Deze stijlvolle, ultradunne laptop van 14 inch zit vol kracht en biedt de razendsnelle prestaties van AMD Ryzenâ„¢ 5000-serie mobiele processors, gecombineerd met verbluffende optionele OLED 2.8K-beelden, een lange batterijduur en een reeks slimme functies waarmee u alles uit uw dag kunt halen.
My Camera Stopped Working
My camera randomly stopped working and my system says it is not connected. I have tried several software solutions but I think I might need to open it up and reconnect something...where can I find a guide to doing this? Thanks!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi @ombreviews
Here's the hardware maintenance manual for the laptop.
Go to p.66 to view the procedure to remove the camera.
If the cable connection seems OK and the camera module needs replacing search online for either 5C20X55554 or 5C20X55556 to find suppliers that suit you best.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
How can I check the connector on the motherboard? Before removing the screen or anything like that. I wasn't seeing anything in the manual for that. Thanks so much!
door
@ombreviews
Not sure with your model but nowadays a lot of the connections between the camera/microphone in the lid and the motherboard is done by a USB connection between the motherboard's IO chipset and a USB controller in the camera/microphone module. The two data wires for the USB are in with the video cable and not a separate cable.
All you can do is check how many cables come from the lid to the motherboard. Most likely there'll be the WiFi antennas connected to the WLAN card and a video cable and that's all.
You would really need to have the schematics for the motherboard to know exactly how it is connected.
I couldn't find a free schematic download online but if the board model number is an NM-D231 then you can purchase it here and it will show the wiring details
door
Voeg je antwoord toe
OMB Reviews zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 15
Altijd: 597
