Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatie- en demontage-informatie voor de vlaggenschip Android-smartphone S20+ van Samsung, uitgebracht in maart 2020.
Front screen replacement kit
The front screen of the phone is cracked and the touch screen doesn't work, do you have a product to replace that and make the touch screen start working again?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Filteren op:
@prithvirajpatel for your phone the touch screen, the glass and the LCD are all "sandwiched" together to make this the display assembly. In your case, it is best to replace the complete Display assembly.
Look in the note of this guide Samsung Galaxy S20 Plus Vervanging van het scherm You'll find that "Some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires you to transplant all of your phone's internals and install a new battery. Make sure you have the correct part before starting this guide.
There is a significant chance that you may break the unreinforced and fragile display panel during this procedure."
It would be best to replace it with something like this Samsung Galaxy S20+ (USA) Screen and Battery - Genuine
Your phone uses an OLED screen and those are not cheap.
Replace a screen and battery assembly for a Samsung Galaxy S20+ smartphone for the US market. Fix issues like a scratched screen, touch issues, or a dead battery. 6.7 Inch 3200 x 1440 pixel AMOLED Display. Afbeelding
Product
$216.99
Was dit antwoord nuttig?
Voeg je antwoord toe
prithviraj patel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 19
Altijd: 910
