Ga door naar hoofdinhoud
Repair and disassembly information for Samsung's S22 smartphone, released in February 2022.
26 Vragen Bekijk alle
Microphones are not working after battery install.
I Installed a new battery into this S22. I replaced the battery because this phone was submerged in water for over an hour and after I completed the drying process the battery appeared to be swelling up so I replaced it. Now everything works except the microphones to make phone calls and record audio. Any Ideas???
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @johnfburckhard
The boards may have needed more than just drying out.
There are two microphones in the phone. The lower one is used when making "normal" calls and the upper one when making "hands free" calls or using the phone away from the face etc although they may be used in conjunction with each other to minimize any background noise that may cause problems with a clear voice being heard. Perhaps that is why both may not be working
The microphones (small gold rectangular component) can be best seen in the Charge port replacement guide (one of the individual repair guides linked in the main guide below) in the images in Steps.16 (upper mic) and Step.23 (lower mic)
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives which may leave conductive residues and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that explains what happens Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Here is the ifixit Samsung Galaxy S22 guide that may help.
If the problem is not resolved by cleaning you may have to purchase the service manual to find out what's wrong. I couldn't find a free download online. You may have better luck. Most Samsung phone service manuals have diagnostic flowcharts showing which components to check for each of the functions of the phone, combined with board layouts showing the location of the components mentioned in the flowchart and some even have component parts lists as well making it easier to find replacement parts if required
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
John F Burckhard zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 79
