Ga door naar hoofdinhoud
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Fan not working even after replacing
Hi all (Dan),
I have a MacBook Pro 2015 13" which has a fan that won't run. I have...
Put a known good fan in
Replaced keyboard and trackpad cable
Replied thermal paste
New SSD
Fresh install
SMC and PRAM
I used 'mac fan controller' which worked, the fan was controllable up to full RPM and all of the RPMs in-between, but the Mac just won't control it. I assume a faulty LB?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@andyc7117 may be not a faulty logic board but a failed part in the fan circuitry. This could be related to an issue with either the Tach circuitry of the fan or the Fan Control circuitry. I would suggest that you start by checking the components and see what results you get.
Copy the image to your computer since there will be times where they may have to disappear ;-)
If nothing else, let's see your logic board. Maybe somebody on here can identify any issues with it. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you. It's started working again after (another) fresh OS install.
door
Voeg je antwoord toe
Andy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 154
