Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Handleidingen voor de Wi-Fi-versie van de iPad mini 5—model A2133. De iPad mini 5 kwam uit in maart 2019 en is de opvolger van de iPad mini 4.
Replacement Battery Zero volts
Hi, my wife’s 3y/o iPad mini 5 died the other morning. Wouldn’t startup, wouldn’t charge.
I tried all the online suggestions but no joy.
I decided to replace the battery but first I removed the old one (partly to check my ability to do this ok) and found it at 0 volts.
So I ordered a new one and, before fitting, was surprised to find it also at 0 volts.
I wouldn’t have been too surprised but the spare battery I had ordered for my own iPad mini 2, two years ago, was still showing 3.5 volts.
However, the battery seller encouraged me to fit it and charge the device. I did this but no joy.
My real question is; “would you expect a NEW battery to arrive CHARGED?” ie. Is it possible I’ve been sold a dud battery?
Many thanks!
Kind regards, Mike.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
That battery is permanently damaged. It would be nearly impossible to restore a battery in that state of charge. Personally would keep pressuring the seller for a refund and get the battery from a more reputable place like here at iFixit or another place.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Many thanks Duck, I’ve got the refund and reordered through iFixit!
Much appreciated
door Deel
@mikefloutier No problem. Glad to help.
door Deel
Hi, it’s me again. I received your replacement battery and installed it but it still won’t start.
I’m now looking for other repair ideas.
door Deel
@mikefloutier best way to do that is by creating a new question. There, give all the details, background of the iPad and everything you have done and tried.
door Deel
Voeg je antwoord toe
Mike Floutier zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 589
