Ga door naar hoofdinhoud
De Lenovo IdeaPad 110-15ISK werd in 2015 door Lenovo in de Verenigde Staten ontwikkeld. De Lenovo IdeaPad 110-15ISK kan worden geïdentificeerd aan de hand van het modelnummer: 80UD.
Second Graphics card not detected
For me, The AMD Radeon card which comes as the second graphics card in this laptop, has completely disappeared in the system. Task manager, Device manager, or dxdiag do not recognize it, and amd driver installer doesn't detect it either, the copy of linux I also have installed on the system, doesn't recognize it either. I haven't opened it and would rather not. What do you think could be the problem?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @amiratashi
Perhaps check in BIOS to see if there's an option to disable the AMD GPU.
If there's not, there's some reason why the GPU is not communicating with the I/O chipset on the motherboard so you will have to open it up and see if anything obvious is wrong. After that you may need the schematics to find out what's happened.
Here's the hardware maintenance manual that will help gain access to the motherboard
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you for your anwser @jayeff
door
Voeg je antwoord toe
Amir Atashi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 429
