Ga door naar hoofdinhoud
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
Should I be worried if I accidentally poked the battery?
I poked the phone battery during a replacement with the tweezers available in the kits. It left a tiny hole. Should I be worried and replace it. I didn’t notice a strong chemical smell.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@jeangabriel5999 possible that you only poked through the outer package. You could cover that with a piece of electrical tape. Since we do not know how deep etc. and to remove all doubt, replacing the battery will give you a sense of security that it is now fixed. :-)
Since you have it already open and since you do seem to be concerned about it, go ahead and replace it. One less worry.
iPhone SE 2020 Vervanging van de batterij
iPhone SE 2020 Battery
Replace a 1821 mAh battery compatible with an iPhone SE 2020. This replacement does not require soldering. Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jean-Gabriel Grimm zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 119
