Ga door naar hoofdinhoud
The larger edition of Samsung's tenth flagship Galaxy phone, released in February 2019. Shipped with Android 9.0 (Pie).
20 Vragen Bekijk alle
Mobile screen is cracked, need to change battery back panel came out
Need to change battery. Back panel glue came out. And battery got swellen
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
@kalam86420 easy enough ;-) Use this guide Samsung Galaxy S10+ Vervanging van de batterij for the repair and you can get the battery from here Galaxy S10+ Battery (depends on where you reside). Due to  shipping regulations, we can only ship lithium-ion batteries to physical addresses inside the contiguous United States (lower 48 states) via Ground shipping methods. We cannot utilize Air shipping methods for shipments containing batteries. If you reside outside the USA you may need to find a supplier closer to your geographic region.
The first guide also shows you how to remove the back cover. If you need to replace it you can get that one from here Galaxy S10+ Rear Glass Panel/Cover and the adhesive to keep it secured is available right here Galaxy S10+ Rear Cover Adhesive
Repair is War on Entropy!
Replace a dead or malfunctioning model EB-BG975ABU battery compatible with a Samsung Galaxy S10+ smartphone. Afbeelding
Product
Galaxy S10+ Battery
$19.99
Replace the custom cut adhesive film that secures the outer edge of the rear cover panel compatible with the Samsung Galaxy S10+ smartphone model #G975U, G975F/DS. Afbeelding
Product
$6.99
Replace a broken or scratched rear panel on a Samsung Galaxy S10+ with this new blank aftermarket rear panel. Afbeelding
Product
$16.99
Was dit antwoord nuttig?
Voeg je antwoord toe
kala m zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 84
