Ga door naar hoofdinhoud
In August 2000, the ninth-generation Corolla was introduced in Japan, with edgier styling and more technology to bring the nameplate into the 21st century.
Windshield washer sprayer sprays uneven
On my 2003 the window washer fluid nozzle over sprays on one side and dribbles on the other. What's causing it and how can I fix it?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @zachariahcoley
You could try inserting an appropriately sized small pin (opened safety pin?) into the affected washer nozzle opening and use it to gently move the direction of the spray in one nozzle i.e. up/down/left/right and do the same in the other and see if that clears any obstruction or you could replace the nozzles, but you may have to then adjust the angle/direction of the spray as well.
Here's a video that in general shows what to do. I don't know what year model Corolla the video pertains to but they're mostly all the same.
Search online for 2003 Corolla windshield washer nozzle to find suppliers that suit you best
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Zachariah Coley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 13
Altijd: 152
