Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
How to remove Red X from Sound Icon
  1. My pc sound is not working. It says no speakers or headphones are plugged in. It puts x mark on volume button. I have tried YouTube videos none of them helped me. I saw your about your website on tiktok. Thanks in advance for your cooperation.
Is dit een goede vraag?
3 opmerkingen
Have you tried clicking the sound button, and opening up sound mixer?
door Deel
Yeah. Didn't work
door Deel
@hajijawaro are you using Windows on this computer? which version? Have you checked under device manager what it tells you about your Sounds output etc? Has it ever worked for you? Did it have Sound before? Anything happened to it?
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
Looks to me like your audio is not being found. You could always try the Windows troubleshooter first. Right-click on the Speaker/Headphone icon . Then select troubleshoot sound problems. That should start the troubleshooting process. LEt us know what it finds.
Depending on your version Windows, you may also want to go and check to see if your audio is enabled/disabled in your device manager.
If all of that looks okay, I would update the audio driver. Check on here for that.
Remember, Toshiba is a crazy company, like Apple only worse. They are really, really paranoid and secretive. Do not expect any help from that company.
Was dit antwoord nuttig?
2 opmerkingen:
I'm afraid. Still my problem is not resolved
door Deel
@hajijawaro you need to let us know what you have tried.
door Deel
Voeg je antwoord toe
melal zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 30
Altijd: 403
