Why the refrigerator is not cooling while the freezer is fine.
why the refrigerator is not cooling?
Is dit een goede vraag?
Hi @zion86944
I'm having problems sourcing information regarding the refrigerator but check if you can hear a fan running inside the freezer compartment when the compressor motor is running.
With most refrigerators that have only one evaporator unit, there's a fan inside the freezer compartment located near the evaporator unit (behind a panel at the back of the compartment - access it through the door at the front of the refrigerator - i.e. remove the panel) and it blows air across the freezing evap unit and into the refrigerator compartment to cool it down to the desired temperature.
The freezer is cold because that's where the evap unit is located.
The fan should stop when a door is opened (either door) and start again when the door is closed. The fan will run as long as the compressor is running as well.
If you can't hear the fan at all then there may be a problem with the fan, the power supply to the fan, the control board or it could be that the fan is completely iced up due to a defrost problem.
With auto defrost refrigerators (I don't know if yours is because I can't find any info on it) the compressor motor is stopped every 8-10 hours and the defrost heater under the evap unit is turned on to melt any accumulated ice off the unit to drain away.
The defrost cycle lasts for about 20-25 minutes after which the compressor is turned on again
If the fan is iced over then it could be due to a faulty defrost heater, defrost thermostat, defrost timer (or control board) or a blocked drain.
You may have more luck if you search for Hisense R-Z270AUK7K parts than I did. At least if you find any suppliers they might have a list of what parts are available if you do find out what's wrong.
Sorry that I can't be of more help.
Was dit antwoord nuttig?
Another strong possibility is the damper control, sometimes called the air diverter. The evaporator fan will always run when the compressor is running, as described above, but this cold air can't just be sent to the refrigerator compartment at all times. If it were, your food would freeze. The temperature has to be regulated. There is a small door between the freezer and refrigerator compartments, with a duct to the evaporator. The damper control uses a capillary tube or a thermistor (in conjunction with a microcontroller) to open or close the door to maintain the proper temperature.
Some newer models have dual evaporators instead of this door. I wasn't able to find any technical information on your model, but I don't think yours is one of those.
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 83
Altijd: 580
4 opmerkingen
Hi @zion86944,
What is the model number of the refrigerator?
door jayeff
Hi @jayeff , it is R-Z270AUK7K
door Zion
Running but not cold.
door Min Thu (မူသင်း)
Hi @minthumuthin
What is not cold, the freezer compartment, the refrigerator compartment or both?
door jayeff
