Ga door naar hoofdinhoud
The Lenovo ThinkPad Yoga 370 has a lightweight, 2-in-1 design, where it can be used anywhere you go as both a laptop and a tablet. Model number: 20JH002AUS.
5 Vragen Bekijk alle
Device not switching on
  • Why is my PC not turning on and also not charging when connected to a power source?
Is dit een goede vraag?
1 Opmerking:
I need an urgent reply 😭😭
door
Voeg een opmerking toe
1 Antwoord
@lanry you are not really telling us a lot here. Would be nice to know what you have checked and if anything has happened to this Thinkpad. Anyhow, I suggest you start with the basics for all devices and check a few things.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Voeg je antwoord toe
Lanry zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 114
