USB C to HDMI stop working
As I mentioned earlier, without any system updates or software-related issues, my connection to my external monitor via USB-C stopped working. I've searched online but haven't found a solution to my problem. Can anyone help or suggest an alternative connection method?
Is dit een goede vraag?
Hi @agptmiranteldit,
Did you end up replacing the USB-C port as suggested by an answer to your other question relating to the problem, earlier this year, you never said whether you have or not?
Change USB-c port
door jayeff
Nope, someone suggested an easier way, but I found that the change didn't address the USB-C issue. However, when I used a stiffer connector, the frequent disconnections disappeared. It's worth noting that this was on a different computer I have, which is model 9350.
door A Gpt (Miranteldit)
@agptmiranteldit
Apologies, I missed seeing the model change.
door jayeff
