In cpc power supplying is not coming
In cpu power supplying is not working
Is dit een goede vraag?
@devika14103 checked the power supply by disconencting the power supply from the motherboard. Then place a jumpoer between the green wire and a black ground wire. Since we do not know exactly what power supply plug you have, it will help if you post a picture of it with your Question. We can then show you where to place the jumper. Voeg afbeeldingen toe aan een bestaande vraag
If it does not work, you know you have a bad power supply. If it does work you need to check the power button as well as the motherboard.
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 75
