Cum se schimba display la telefon
Mia intrat la apă și nu mai se vede nimic
Google translate:
How to change the display on the phone
Mia entered the water and nothing can be seen
Is dit een goede vraag?
Google translate:
Besides just changing the display you may have to clean the whole phone as well.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your phone and then remove the battery as soon as possible from the phone to minimize any further damage.
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it check the label to verify the amount of IPA. The higher the percentage of IPA the better
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there. The ends of any flex cables and their connectors need to be cleaned as well
Hopefully after you have done all this the phone might possibly work correctly again.
Search online for Samsung GT-C3050 Display to find suppliers that suit you best.
Here is a teardown video that will help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Google translate:
Pe lângă doar schimbarea afișajului, poate fi necesar să curățați și întregul telefon.
Impuritățile din apă provoacă coroziune și oferă circuite pentru electricitate care nu erau în proiectarea de funcționare a telefonului și ar putea deteriora componentele. Coroziunea începe imediat și continuă până când este complet curățată
Mai întâi nu încercați să încărcați sau să porniți telefonul și apoi scoateți bateria cât mai curând posibil din telefon pentru a minimiza orice alte daune.
Apoi trebuie să dezasamblați restul telefonului și să curățați toate părțile afectate folosind alcool izopropilic 99%+ (disponibil la magazinele de piese electronice) pentru a îndepărta toate urmele de coroziune și apă. Dacă este posibil, nu utilizați „alcool pentru frecare”, deoarece în unele cazuri acesta este doar 70% IPA sau mai puțin, poate conține aditivi și nu este la fel de eficient. Dacă trebuie să îl utilizați, verificați eticheta pentru a verifica cantitatea de IPA. Cu cât este mai mare procentul de IPA, cu atât mai bine
Iată un link care descrie procesul. Electronics Water Damage
Ca întotdeauna în cazul electronicelor, în special pcb-ul montat pe suprafață, fiți blând atunci când manipulați și mai ales când îndepărtați coroziunea. Nu doriți să eliminați nicio componentă de pe placă. Îndepărtați scuturile care ar putea acoperi unele componente, deoarece apa poate fi intrat sub acolo. Capetele oricăror cabluri flexibile și conectorii acestora trebuie, de asemenea, curățate
Sperăm că, după ce ați făcut toate acestea, telefonul ar putea funcționa din nou corect.
Căutați online Samsung GT-C3050 Display pentru a găsi furnizorii care vi se potrivesc cel mai bine.
Iată o demontare video care vă va ajuta.
Dacă acest proces pare prea descurajator, duceți-vă telefonul la un serviciu de reparații de telefon profesionist, reputat, cu experiență în repararea daunelor cauzate de lichide și cereți o ofertă pentru o reparație. Dacă decideți să faceți acest lucru, faceți-o mai devreme decât mai târziu.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 41
