Ga door naar hoofdinhoud
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
My Samsung Galaxy s2 is not charging
I've had this phone for many years and I've gone back to it to fix it many times but never managed to do so
So basically this phone has a changing problem sometimes it did others it didn't charge and after a while it stop charging completely i thought buying a new replacement charging port will do the trick i bought one and still nothing no charge
I was thinking it might be the battery but if it was the battery wouldn't it stop charging in the first place because when i moved the Cable a bit it was charging but i have no idea
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @ellusion
If the battery hasn't been recharged for a long while then most probably it has become depleted beyond recovery and needs to be replaced.
If you want to check if it is getting power to charge, here's the charging flowchart from the service manual for the phone.
On p.37 is the schematic for the charging circuit and p.28-p.29 have the board layout.
There's also a parts list on p.9-p.18
Hopefully this will help you to find out what's wrong.
Was dit antwoord nuttig?
Score 3
3 opmerkingen:
Thank you so much kind sir
door
@ellusion
Thanks for the feedback.
For some strange reason the ifixit spam iRobot marked your comments as spam and deleted them and has deducted 100 rep pts for every deletion.
I have restored your lost rep points and deleted the duplicate comments.
Just tag my user name (under my avatar) in a comment/answer or question to contact me if it occurs again and I'll pass it on to the admin.
Cheers
Moderator
door
@jayeff thank you so much my internet is slow and sometimes the comment gets send 2 times and it's the second time this has happened
door
Voeg je antwoord toe
Ellusion zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 18
Altijd: 256
