Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
screen working but blank
the screen is working but the screen is blank mobile touch is working but the screen is blank purely black
Is dit een goede vraag?
3 opmerkingen:
Screen is black but can hear the on /off button is pressed
door Deel
@supriyatalekar
Did you try what was suggested in the answer below?
door Deel
Yes when i charge it vibrate but it screen is blank
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Hi @asgamerguru
Check if the display flex cable is securely connected to the systemboard.
If it is then here are some images showing the no display troubleshooting flowchart from the service manual. I've included zoomed in images and normal size images showing the location of the components mentioned in the flowchart.
Afbeelding
Afbeelding
Afbeelding
(click on images)
If all the tests seem to be OK the screen will have to be replaced.
Search online for GH82-22836A GH82-22509A to find suppliers that suit you best.
Here's a video that shows what to do.
If doing this yourself seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote to repair the phone.
Was dit antwoord nuttig?
Voeg je antwoord toe
asgamer guru zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 17
Altijd: 476
