Dead Pixel Stuck On Screen
I Got Dead Pixel On Screen Due To Water Damage
Is dit een goede vraag?
Dead pixels can be frustrating, especially when they're caused by factors like water damage. Here's what you can do:
Remember that repairing hardware issues can be complex and might require specialized tools and expertise. It's often best to consult with professionals, especially when it comes to delicate components like screens.
Was dit antwoord nuttig?
@nimeshsuranga are you using a chatbot for your answers?
@bhagathsin51397 since you are dealing with a water damaged device, you also need to make sure that you take care of the water damage. If you do not, then it is possible that your phone will continue to corrode and may fail at a later point.
First thing you want to do is to clean it. Disassemble your phone using something like this as your guide . You must remove all EMI shields from the boards. After you remove those, clean the boards, connectors and all with +90% isopropyl alcohol. Follow this guide, even so it was written for an Apple iPhone 3G, all the points are still pertinent to your phone as well. While you clean your boards, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. It is possible that you have a bad LCD and replacing the display assembly may fix it. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 994
