Ga door naar hoofdinhoud
1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
20 Vragen Bekijk alle
installed replacement battery, calibrated & charged lasts 3 hours
How long does fully charged replacement battery last?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
@kismet2222 so it really depends.
In general, even if battery health is perfect, batteries on older machines are not going to last as long as they did when the machine was new because modern software is more demanding.
When you couple that with the general poor quality of 3rd party replacement batteries, 3-4 hours sounds about right.
Was dit antwoord nuttig?
1 Opmerking:
Thanks. Very helpful. Makes sense.
door
Let’s get a better handle on what’s happening! Install this gem of an App! CoconutBattery then post a snapshot of the main apps window.
A fresh battery will last as long as what your system was able to before! But without a clean measure there are many reasons why it might appear the systems run time is not as long.
The quality and age of the battery can also skew things.
Voeg je antwoord toe
Kismet2222 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 91
