@tibe Rice does not work. It does absolutely nothing to help you with this repair. All it does is waste time and waste food. Check here https://www.ifixit.com/News/30047/rice-i... for more on this.
For now, you want to stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using these guides . You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide , and even so it was written for a iPhone 3G all the points are still pertinent to your phone. While you clean your board, check for any obvious damage, like burned or missing components etc.
When it is properly cleaned, you must replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
Translation
@tibe Rijst werkt niet. Het helpt je absoluut niet bij deze reparatie. Het enige wat het doet is tijd verspillen en voedsel verspillen. Kijk hier https://www.ifixit.com/News/30047/rice-i... voor meer informatie.
Voor nu wil je stoppen met proberen je telefoon op te laden, te synchroniseren of op een andere manier te gebruiken. Dit kan een slechte situatie mogelijk verergeren en je telefoon verder beschadigen.
Het volgende wat je moet doen is de telefoon schoonmaken. Haal uw telefoon uit elkaar met behulp van deze gidsen . Je moet alle EMI-schilden verwijderen. Als je die niet verwijdert, kun je net zo goed niets doen. Nadat je die verwijderd hebt, maak je de hele printplaat, connectoren en alles schoon met +90% isopropylalcohol. Volg this guide, en ook al is het geschreven voor een iPhone 3G, alle punten zijn nog steeds relevant voor jouw telefoon. Terwijl je je printplaat schoonmaakt, controleer je op duidelijke schade, zoals verbrande of ontbrekende componenten enz.
Als het goed is schoongemaakt, moet je de batterij vervangen. Dit is een must en geen optie. De batterij zal het begeven als je er nu niets aan doet.
Al deze stappen zijn bedoeld om uitstel van defecten door corrosie te voorkomen. Het beste zou zijn om de batterij te reinigen met een ultrasoonreiniger, maar als je daar geen toegang toe hebt, zal dit in ieder geval helpen. Als je dit allemaal hebt gedaan, zet je je telefoon weer in elkaar en evalueer je hem opnieuw. Totdat het is schoongemaakt, blijft alles een gok. Zelfs met dit alles is de kans klein dat waterschade volledig kan worden gerepareerd, maar je kunt het in ieder geval proberen.
