Ga door naar hoofdinhoud
Uitgebracht op 3 december 1994 in Japan en op 9 september 1995 in Noord-Amerika. Modellen SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x en SCPH-900x.
Ps1 problems with motherboard
My ps1 scph-9002 has a problem with motherboad, it turns on but no video output, no audio or any spinning. Everything is connected.Should i replace the motherboard or try to fix it? Previous user had istalled modchip, so problem could be there also
Also problem is not caused by tv or video output cable
Is dit een goede vraag?
2 opmerkingen:
Have you check if the Av output are damaged?
door
Nothing is turning on, av output and motherboard looks fine
door
Voeg een opmerking toe
1 Antwoord
Make sure your PSU cables are connected, and check its voltage with a DMM if you’re sure it is properly connected to the board. It’s more likely to be the board’s power supply if nothing is happening on the motherboard.
Was dit antwoord nuttig?
Voeg je antwoord toe
Valtsu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 358
