Ga door naar hoofdinhoud
Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Vragen Bekijk alle
Battery turn off at 30 % charge
Hello,
I just bought a Iphone 3gs and my Problem is that if the battery reaches a level around 30% , the phone just turns off . The only way to get it back running is to charge it up , so that is has more then 30%. Can you tell me how to fix the problem please ?? fyi i dont have the phone jailbreaked or anything , i just bought it on ebay und received it reseted without any programs on it.
yours sincerly
Is dit een goede vraag?
Score -1
1 Opmerking
done ;) thanks again !
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Try replacing the battery and if that doesn't work replace the logic board.
iPhone 3GS Battery Afbeelding
Product
iPhone 3GS Battery
$14.99
Was dit antwoord nuttig?
Score 1
9 opmerkingen:
+...I would definitely start with the battery. After that there are a few more things you can try before you start replacing a logic board....
door
ok thanks but why do you think its the logic board ?? the phone just runs fine and its far too expensive to exchange a logic board on a 3gs i just paid 214 euro for mine
door
Try replacing the battery first and that will probably fix it.
door
ok i just bought this one :
http://www.ebay.de/itm/120818059443?ssPa...
hope it will work
door
It should work.
door
4 commentaren meer tonen
Voeg je antwoord toe
Dominic zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 11
Altijd: 3,108
