Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
De 7e generatie Surface Pro, uitgebracht in oktober 2019. Verkrijgbaar in platina en zwart. Modelnummer: 1866.
Blue Screen of Death
My mom's Microsoft Surface Pro 7's original charger stopped working, so she used my MacBook charger. It worked for a while, and then the computer suddenly shut off when she was doing some test. When we charged the Surface back up, we decided to turn it on. We saw the blue screen of death. It brought us to the automatic repair thingy, and it said, "Your PC did not start correctly" So, I clicked the restart button, and it brought us to the blue screen of death again, going to the automatic repair, showing the same thing again. I decided to go to Advanced Options, Troubleshoot, and Reset PC. And it was asking for a BitLocker recovery key. As we remember, we got the laptop from Costco and set it up by ourselves. I checked my mom's account, and the Bitlocker recovery key is not there. Also, the stop code is BAD_SYSTEM_CONFIG_INFO. Is there a solution? We don't need the data back.
Afbeelding
Afbeelding
Update (08/04/23)
Just an update. Actually, the software was corrupted. I reinstalled windows 10 with a usb flash drive, and the computer is back and running!
Is dit een goede vraag?
1 Opmerking
@tanveerzubair copy your update from today to an answer. That way it can be accepted as a solution and the next person with issues similar to yours, will know what worked.
door Deel
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Was dit antwoord nuttig?
Het nuttigste antwoord
That sounds like you fried something inside. Different computers need different amperages and voltages from their power supplies. Just because the Mac charger fits, doesn’t mean it’s gonna work very well. You’re probably better off taking it to a repair shop, unless you want to disassemble the whole thing, inspect every single part for damage, desolder any burnt capacitors and transistors, solder on new ones, and when all of that inevitably doesn’t work, replace all of the damaged internals. Trust me, I know from experience. My PC’s motherboard was completely defective, and I spent weeks trying to fix it, and I never was able to.
Score 1
Voeg je antwoord toe
EverythingAwesomeTech zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 55
Altijd: 1,234
