@madmax94338 "charged with only one another charger" means you've tried multiple chargers. You need to let us know what the voltage outputs on those chargers are. In particular, we'd be interested in the voltages for the one that works. Also, there is a possibility that (if you tried other chargers) the USB-C port is having issues. Double check for that as well.
@madmax94338 this sounds like a daughter board issue. That is your charging board. Something like this one
If that doesn't change anything, follow the Samsung flow chart and measure the components accordingly. The components are the ones the blue arrows are pointing to.
For any abnormality you find while you work on your phone, you can always add pictures to your Question. That way we can see what you see.
Voeg afbeeldingen toe aan een bestaande vraag
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
