Ga door naar hoofdinhoud
Slow spinning side brush
My Roomba 535 the side brush is turning slowly, even with a fully charged battery, I already changed the battery for a new one but it still keeps turning slowly. any repair suggestions?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi @sandronardi
Could be a sticking or faulty side brush motor (example only).
Here's a video that may help.
Read some of the comments below the video as to what some of the problems with the side brush motor can be.
If the motor is faulty, replacements are available online. Search for Roomba 500 series side brush motor to find suppliers that suit you best.
Was dit antwoord nuttig?
3 opmerkingen:
Thank you friend;
I've replaced the side brush motor, but it still runs slow.
door
Hi @sandronardi did you replace just the motor, or the whole motor and gearcase assembly. If you replaced the whole assembly, then it might be a control board problem. The gears have teeth that break and make the sweeper run slowly or erratically. Here's a link to a troubleshooting page:Roomba Sweeper Brush Not Spinning
door
Buddy, replaced the whole assembly, put a new engine. And the brush keeps turning slowly.
door
Voeg je antwoord toe
Sandro Nardi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 220
