Ga door naar hoofdinhoud
Speelgoedquadcopter met camera, bediend via wifi met een smartphone.
What is the 3-Axis Accelerometer Specification / Part Number
The AR Drone breakdown is excellent, thank you. I have just one question.
Do you have the specification/part number for the 3-axis accelerometer which I presume is one of the components on the Navigation Board.
Many thanks
Mick (Masters Student)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
check this "For the inertial guidance system, ACAL recommended a Bosch BMA150 3-axis accelerometer which works in conjunction with a 2-axis gyrometer and a 1-axis yaw gyrometer to provide the data for the auto-pilot. Initially. the AR.Drone used a QFN-packaged accelerometer, but ACAL suggested migrating to the LGA-packaged BMA150. This reduced both the power consumption and cost," from here. the datasheet is available here. Just in case you need the navigation board, is is available at places like this. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Mick Nadin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 24
Altijd: 1,869
