Ga door naar hoofdinhoud
Support and repair information for the Xiaomi Mi Band fitness tracker.
20 Vragen Bekijk alle
Can the battery be replaced/fixed?
Over charge the battery now it last just a day where as before I only need to charge the band once a month
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
@muhammadnaqib yes it can but it's not easy. The challenge will be to open the device. Check on videos like this to get an idea of what is involved. Depending on your device model, do an online search for the battery ones you have it open and can read the numbers on the battery. If you are stuck or see something that requires more info/help, post some pictures of that with your Question. Voeg afbeeldingen toe aan een bestaande vraag
While you work on your device, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Was dit antwoord nuttig?
Voeg je antwoord toe
Muhammad Naqib zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 29
Altijd: 271
