Any special measures required to start a brand new pu ichmp?
I just installed a brand new UP3/E. When I switch on power, nothing happens at all. No LED shows any light, no sound from the pump. It is definetely filled with water, except the upper half of the inlet filter. When I loose the front plate, water pours out. Same with the bleed screw. The cabling is correct, as my old pump ist working fine on the very same connections. Is it dead on arrival, or what may I need to do to start the pump for the first time?
BTW, the manual mentions situations where a reset may be required, but seems not to explain how to perfom one. So how does it work?
Is dit een goede vraag?
