Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Reparatiehandleidingen en informatie voor broodbakmachines.
Can the computer program be reset?
I have a Kenmore bread machine, the computer needs to be re-programmed.
Update 6/9/23
It's a Kenmore; model 6G22, I think?
Is dit een goede vraag?
Score 2
4 opmerkingen
@janetschuroll what exact model is your Bread Maker? What happened to it that makes you think it needs to be reprogrammed?
door Deel
When I turn it on, it starts in the middle of the mixing cycle.
door Deel
door Deel
I have the same issue with my Gorenje bm1600wg bread maker.
The 15 and 16 manual programs are failed to operate. After selecting one of them it's skipped to the next program.
I need a hard reset method for this machine. Pls help me!
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
It can likely be reset by following the instructions below. Most of the bread machines I have used follow the same sort of reset process. If you provide the brand and the model you have I can research the correct reset method. This information will also come with the instruction booklet that came with your machine. If you have that handy.
Press and hold the Stop/Start button for ten seconds to cancel the program. If this is ineffective turn the bread maker off at the power for twenty minutes and the bread maker will reset.
I hope this helps.
Monte
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
It's a Kenmore; model 6G22, I think? Looked in the manual I got, didn't see any help there. Will try your solution in the morning. Thanks.
door Deel
Thanks so much for getting me out of that dilemma! It worked.... Very grateful!
door Deel
Voeg je antwoord toe
Janet Schuroll zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 51
Altijd: 1,589
