Ga door naar hoofdinhoud
The Theragun PRO is designed with a powerful motor that delivers up to 60 pounds of force, and has a customizable speed range of 1750 to 2400 percussions per minute. It features a rechargeable lithium-ion battery that provides up to 300 minutes of use per charge, and a built-in OLED screen that displays speed and battery life.
5 Vragen Bekijk alle
How do I open the case on the Theragun Elite to access the battery?
Hi everyone, I've come here for some help fixing a Theragun Elite.
To give you the backstory, as this may help out others, I bought this as a gift for my wife, but the device would not take a charge. We returned this to the retailer who exchanged it for another new device, but that had the same fault. Looks like there are hundreds of them with dud batteries.
Having done our research this is a really common fault and we were advised by the manufacturer that it would be best to replace with them directly.
What they did was send us out a brand new unit, directly and asked us to "dispose" of the faulty one. That doesn't seem like the right thing to do, so I wanted to see if I could do a repair on this and then give this to a family member.
However, I can't get much further than this (see pics)
I don't want to wreck the casing any more than I have done already. Any suggestions with annotations and arrows would be very helpful :)
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@chrisbower I can't make out on your pictures, if you "popped" the panel around the switches off as well. I believe there to be a screw or two that need to be removed. Those are in the vicinity of the arrows.
A small stiff putty knife or plastic opening tools will work better for those panels. They don't get quite as chewed up with those. The panels are a PITA to remove since the tabs are really tight.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
That's great many thanks @oldturkey03 - I will give that a try. I have some plastic spudger tools somewhere,
door
So what happened? Can you provide helpful pics for us?
door
Voeg je antwoord toe
Chris Bower zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 19
Afgelopen 7 dagen: 110
Afgelopen 30 dagen: 405
Altijd: 1,906
