Tv will not turn on
Have a Vizio tv. Mod#M70-C3 when i press standby button sometimes the standby light will come on fo 10 sec. Then fades away Sometimes standby does not come on at at all, removed power supply and shorted pins PS-ON with 5VS THEN proceeded to measure all pins which all measure correct including 12Vs but 2 pins marked 24v t- con have no voltage, is this the correct way to test power supply.
Is dit een goede vraag?
Can you uload a picture of your power supply? Voeg afbeeldingen toe aan een bestaande vraag
door Andrew S
