Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Light kondigde in oktober 2015 een zelfstandige computationele camera aan, de L16. Veel mensen zijn geïnteresseerd in hoe ze de interne batterij van deze camera kunnen vervangen om de levensduur van het apparaat te verlengen.
How can I replace the battery?
My battery will just hold enough power to start up and then It shuts down. If I have the power cable attached It will turn on long enough for the name logo to appear and then it goes off again! So sad! :-(
Is dit een goede vraag?
Score 2
1 Opmerking
Has anyone tried jumpstarting the battery through the 11 pins at the bottom of the camera? I've seen videos on YouTube that make me think something like that would be possible.
door Deel
Voeg een opmerking toe
1 Antwoord
Filteren op:
Gekozen oplossing
@joeazzato there are plenty of picture of the L16 but never enough information about how to get to the battery. I strongly suggest you go to this site and safe all the information to your personal drive. Nobody knows how long it will be around. These are not step by step instructions, but more of a teardown. So use caution and care when you disassemble it. Also, teh damage to the housing can most likely be minimized by using the proper opening tools and some heat to loosen any adhesive etc. Lots of trial and error :-)
You are now the pathfinder for this :-) While you work on it to replace your battery, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will greatly appreciate this.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Joe Azzato zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 41
Altijd: 1,301
