Ga door naar hoofdinhoud
LG 17" TV HD Monitor
7 Vragen Bekijk alle
How can I fix my tv earial antennae
My aerial antenna got broken how can i fix it
Is dit een goede vraag?
1 Opmerking:
Tony, you haven't given us enough to go on in order to help you.
I'm reading this as you saying that the over-the-air TV antenna you have hooked up to your LG television has broken, is that right?
Okay, so broken how? What exactly is wrong with it? There are a million definitions of "broken" and we can't possibly know what you mean.
In addition, we need to know what kind of antenna you have. Does it have a manufacturer and model number somewhere on it? If not, you'll need to post a picture so we can get some idea of what it is. That's not a bad idea, especially if you can show is in a photo what's broken.
Voeg afbeeldingen toe aan een bestaande vraag
door
Voeg een opmerking toe
1 Antwoord
@tonykipleting you listed your TV as an LG 17LX1R. That particular TV doesn't have an antenna. It has an antenna jack that is part of the main board.
If there are issues with the jack, you need to either replace the main board or try and find the part that is "broken" and replace it on the board. That will require some good tools and skills. So let us know what is going on with your TV.
For anything else, use the service manual LG 17lx1r SM
Was dit antwoord nuttig?
Voeg je antwoord toe
Tony Kipleting zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 7
Altijd: 133
