Ga door naar hoofdinhoud
De XPS 13 9360 is een 13-inch laptop uit 2016 met een zevende-generatie Intel-processor. Het model werd in 2017 geüpdatet met een achtste-generatie processor.
Battery Replacement problem for Dell 9360
I recently replaced the battery for my Dell 9360 using the Dell XPS 13 9360 Replacement Battery kit from iFixit, and it seemed to work fine for a few days, but now my battery doesn't seem to be charging properly. I followed the battery replacement instructions meticulously (Dell XPS 13 9360 reservebatterij vervangen). However, now my battery often gets stuck charging at odd numbers like 32% for hours on end (similar to this post: New 97w Battery Replacement - Not charging past 47%) and will last < 2 hours without being plugged in. Somewhat relatedly, whenever it is plugged in, the fan is usually whirring a lot trying to keep cool.
I made a battery report like the post above's answer by @jayeff suggested. According to it, I have a 60,002 mWh design capacity, and a 45,288 mWh full charge capacity. Are these two numbers sufficiently close to each other? Do I have a bad battery? Is this a calibration problem? Did I just buy the wrong one??
Any help is appreciated!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @matthewwhi66266
It looks like a bad battery.
Looking at the figures you posted it is only charging to 75% which is poor considering it is supposed to be new.
Contact ifixit about the problem and get a replacement.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Voeg je antwoord toe
Matthew Whitley zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 534
