Ga door naar hoofdinhoud
Reparatie- en demontage-informatie voor de draadloze gaming-headset G533 van Logitech. De G533 is te herkennen aan het modelnummer A-00072. De headset werd uitgebracht in januari 2017.
Mic randomly stopped working
I can hear the beep which indicates my mic is being turned on when the mic is flipped up to mute and down to unmute. Although i hear the headset is registering the mic being used for some reason, it just stopped working.
does anyone have experience replacing the mic on one of these? if so please share your experience and point me in the right direction for replacement parts.
thank you in advance.
Is dit een goede vraag?
Score 3
1 Opmerking
I had the same issue with 2 Headsets I bought used. One had this from the moment I bought it, the 2nd worked fine for about 1 year.
I guess the problem is a cable failure in the lever mechanism
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
Hi HawgDawg,
I was going to answer, but ran across someone else with a similar problem and the first comment on that question was pretty much exactly what I was going to say, so I'll just link to that question and let you read it for yourself.
Mic doesn’t work - Logitech G533 - iFixit
See the comment by F Dryer (@notbroken ) for a very good explanation of exactly what I was thinking.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thanks for the reply Jerry
I can't seem to find the comment you're referring to, the thread you linked was helpful though.
door
Voeg je antwoord toe
HawgDawg zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 36
Altijd: 3,611
