Ga door naar hoofdinhoud
Reparatie- en demontage-informatie voor de draadloze gaming-headset G533 van Logitech. De G533 is te herkennen aan het modelnummer A-00072. De headset werd uitgebracht in januari 2017.
Mic doesn’t work
My mic doesn’t work all the time.
Is dit een goede vraag?
1 Opmerking:
My guess is an intermittent mike may be the result of wire damage. You may have to carefully disassemble the headpiece containing the mike and wiring to examine for wire damage, especially at the point(s) of flex. If visible wire damage isn't seen then a continuity test to each wire of the mike is needed to determine which wire broke inside insulation. Soldering skills would be needed to repair wire damage. If you find and repair damage, try it first before reassembling everything, exercising mike movement to ensure the repair is complete.
door
Voeg een opmerking toe
1 Antwoord
This is not a good question because it gives no history or info relative to when and what was tried to troubleshoot it.
Best guess is a broken lead wire, usually close to an end or connector connection.
Least likely is something internal to the headset unless the mike boom has been move a lot to extreme positions.
Was dit antwoord nuttig?
Voeg je antwoord toe
afyuqnjklpi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 40
Altijd: 3,910
