Ga door naar hoofdinhoud
Released August 30, 2019 with a resolution of 240 × 320 pixels.
Why is my keypad not working?
Keypad 789 is faulty
Is dit een goede vraag?
Score 7
2 opmerkingen
phone dead please my prv solution my mobile itel ace my mobile water damage
door
Dissemble the phone's keypad
And then, open the button then you clean all the dust and debris it's components carefully without and further damage
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@ransonmugalla take a look at this guide Itel 2163 Disassembly - iFixit Repair Guide Step 4 (not the greatest images but it should work) shows the membrane and the contacts for your keypad. Clean the membrane and the contacts with an eraser. I like to use the erasers that are at the end of a pencil. If that does not work for you, check ideas like this one as well as on here for a deeper repair. Looks like this is a common issue with that model.
While you work on your phone and repair the keypad, take lots of good pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Was dit antwoord nuttig?
Score 7
Voeg je antwoord toe
Ranson Mugalla zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 66
Altijd: 1,183
