which electrical component is located near the analog stick
I have just replaced the left analog stick but now the capcitor near by is gone and the left paddles are not function. The number at the capacitor is CR14. Does anyone know what kind of SMD capacitor it is? Thanks in advance.
Electronic part before it's gone:
Mark on the component:
Update (04/08/23)
Just a picture of the capacitor before ...
Update (04/11/23)
First, thanks for your reply. I appriciate your help with this. For Q1.1 I can just say, that I have guessed this could be a capacitor. Sorry for the confusion. Now I agree to OldTurkey03 that this could be a diode.
For Q1.2 I have made a picture of the same component on the other side of the controller board. It has the same mark on it like the missing one. So this should help to find the right type. But I could not find anything like this on internet.
To Q1.3 the white shiny material on the controller board is not a water mark. It behavior is like skin cream. You can find it on every solder of this controller board. I had also never a water damage with this controller.
Addtional to the question I can tell you how I losed the component:
The controlles had a left thumb-stick issue. So I wanted to replace the analog stick with a new one. To remove the analog stick I had to heat up the solder higher than I thought. This heated up also the controller board and the component next to the solder of the analog stick. I didnt saw that and after removing the analog stick the component was also missing.
If I follow the electrical lines on the controller board the component seems to be a part of the vibrations motors. The buttons of the controller are still working. But I could not check the vibrations motor sepratly.
So I hope this helps to understand my issue... thanks again for your time and please don't be angry about my english. It's not my motherlanguage.
Is dit een goede vraag?
Need more info and a clear image of the board.
door Jade
Sorry, I had uploaded a picture of it. But the spam filter removed it. I try it again. Hope it works.
Additional I can now say what the SMD part has marked on, it is "0A" like the same component on the right side.
door CS_Nubie
@csnubie you need to edit your QUESTION to add images. Use this guide Voeg afbeeldingen toe aan een bestaande vraag
door oldturkey03
@csnubie cleared up your SPAM deletion and added the image. Rough weekend with SPAM on here, so things are a bit tight and iRobot getting tough with what it thinks is SPAM :-)
BTW that part actually looks like a Diode
door oldturkey03
@oldturkey03 Thanks for clearing the spam.
I would also agree that the part is a diode. But what kind of a diode?
door CS_Nubie
