Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Krachtige tabletcomputer van de 3e generatie, uitgebracht door Apple in oktober 2018. Modellen A1876, A2014 en A1895.
True Tone functionality after screen replacement
Hope all is well!
I’ve looked around other posts, but cannot seem to get a straight answer!
So going to the experts once again!
But iPad Pros, specifically the 2018 models, when the screen is replaced and the ambient light sensor is transferred successfully, does the iPad retain the True Tone functionality?
Thanks everyone in advance!
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
Filteren op:
If it's anything like the iPhone, you'll need to transfer the screen serial number to the new display to keep true tone. There are tools out there for iPhones but I'm not sure about iPads. In some cases no tool may be available at the moment and may require you to transfer a soldered on chip(s) from the old display to the new one. If that's the case, you'll need someone that is skilled in micro soldering. This isn't a repair you can or should DIY unfortunately because it requires a lot of special tools like a microscope and hot air station.
Was dit antwoord nuttig?
Voeg je antwoord toe
jappleseed481 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 43
Altijd: 836
