Ga door naar hoofdinhoud
Is there a fuse there?
Where is located the fuse and how can I approach it?
Is dit een goede vraag?
2 opmerkingen:
There are numerous fuses. Can you describe the symptoms?
door
The printer does not show any sign of life after an unclear power interruption.
door
Voeg een opmerking toe
1 Antwoord
Filteren op:
Try the following methods to restore power to the Brother machine:
3.1 Method 1
  1. Remove the power cord for at least 30 seconds.
  2. Press and hold the ON/OFF button down, and then insert the power cord back into the machine.
  3. Do not release the ON/OFF button until the machine has been powered on completely or after 15 seconds.
  4. Repeat this procedure up to three times if necessary.
3.2 method 2
  2. Remove the paper tray from the machine.
  3. Reconnect the power cord, and then power the machine on.
  4. When the machine has been powered on completely, insert the paper tray back into the machine.
If you still cannot power the machine on, then you likely have a bad power supply which can be purchased here...
https://www.ebay.com/itm/321986636857
Was dit antwoord nuttig?
1 Opmerking:
No, it did not help, (BTW, how can the paper tray position affect the power?) The problem may be in the power supply. Is there a procedure description how to replace it?
door
Voeg je antwoord toe
tvarozna zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 33
Altijd: 1,105
