I broke the housing around my key ignition where there are security wi
I broke my housing around my ignition switch ,and the wires have no place to be attached now ,I can still put in new switch and key but truck just starts and dies immediately is there a way I can install a 1990 GMC Sierra steering column into this 2004 Silverado and make truck run ,or eliminate the wires that have been broken away from housing and make it run I can't afford column or to have professionally fixed can anyone walk me threw the process to either hotwire this or bypass the switch and security
Is dit een goede vraag?
@larryvoss sounds like quite the damage? How did that happen? Anyhow, post some good pictures of what you got going on there. That way we can see what you see and hopefully help you out further. Voeg afbeeldingen toe aan een bestaande vraag
door oldturkey03
