Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
USB Power Port Clip Broken
I went to plug in my 30GB iPod classic and it came loose. I took it out and out came the little plug that connects to the usb cable. After taking it apart I found out that the pins have been bent in various directions. What do i need to do to repair or should i just give up and get a new one.
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Gabriel Petersen, if I understand you correctly, the part on the bottom of your iPofd come loose? That is your dock connector and it is a part of the logic board. It is soldered on to it. If you are good at soldering very small, tedious components, you can purchase a replacement from here. If you are not comfortable doing that kind of work, I would suggest that you purchase a replacement logic board from places like this. and the guide for your repair is here. Hope this helps, good luck.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Gabriel Petersen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 422
