Ga door naar hoofdinhoud
De vierde generatie smartwatch van Apple, met optionele mobiele connectiviteit, uitgebracht op 21 september 2018.
What is this part for?
I’m 13 years old and trying to take responsibility for breaking my Apple watch by fixing it myself.
I have the screen replacement, but this part came out of my watch. I think it is the force touch sensor, but I wanted to double check.
EDIT: My screen replacement is below. It is off-brand.
If possible could I get some help?
Afbeelding
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
If you review Step 8 in this Teardown of the Watch you’ll see the pictured part is not the ForceTouch sensor Demontage van de Apple Watch Series 4
As to what it is would be tough as there is not enough information in the image to gain a sense of scale or understanding the parts construction.
Using the teardown can you see what it is.
Update (03/05/2023)
@ebp049x - OK, was out enjoying the day sorry for not piping up sooner.
The display assembly is made up of a collection of discrete elements the crystal glass, the touch plate, the OLED screen, the backplate which holds the NFC chip.
What I see is a bunch of mangled parts and you still have part of the display assembly attached to the watches body.
You will need to get a new display assembly to fix this. Here’s the guide which also has the parts info Apple Watch Series 4 Vervanging van het scherm
Apple Watch Series 4 Afbeelding
Handleiding
Moeilijkheid:
Gemiddeld
Apple Watch Series 4 Scherm Afbeelding
Handleiding
Moeilijkheid:
Moeilijk
1 - 2 hours
Was dit antwoord nuttig?
7 opmerkingen:
It is part of the screen, which is not disassembled in the teardown.
door
That's the touch screen. Don't worry about it.
door
If I do not reapply it or do not purchase a replacement, will anything on the watch be affected?
door
@ebp049x That is already on the replacement screen. Nothing to worry about. Good luck with the repair.
door
I posted an update
door
2 commentaren meer tonen
Voeg je antwoord toe
Eshaan Bhargav Patel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 26
Altijd: 460
