Ga door naar hoofdinhoud
A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by an SI using off-the-shelf parts.
My pc is also power cycling, Any help or tips?
My pc is also power cycling, I took everything apart and placed it back together and it still does it. Any help or tips?
Update (02/26/2023)
@jayeff
Motherboard: AMD ASRockB450MPro4
PSU: ROSEWILL ARC550 80+ bronze
CPU: ryzen 7 5700G
GPU: Nvidia geforce gtx 1650
RAM: 2x 8gb DDR4 3600
I turn It on and everything lights up but get a black screen for around 30 seconds, then it turns off and immediately starts up by itself again, then repeats the process
No its not brand new
Is dit een goede vraag?
Score 1
1 Opmerking:
Mine is also doing the same thing and on top of which I put. when I push the power button it wouldn't Start all in all. it was doing was sitting for about a month or two, unused. So I had to bypass the start switch and jump the wires to get it to try to start and then it power cycle. I'm thinking it might be the CMOS battery Keeping it from running post? I'm going to try that route today and see if that fixes it. If so, I'll post back up on here the results.
door
Voeg een opmerking toe
1 Antwoord
Hi @hugetree
Try a power refresh in case it is a corrupted BIOS.
Turn off the PC and remove the power cord from the PSU.
Open the desktop and remove the coin cell RTC (aka CMOS) battery from the motherboard.
Press and hold the Power button for a full 30 seconds and then release it.
Reinsert the RTC battery (usually +ve on top as marked on the battery)
Reassemble the desktop and connect power to the PSU, turn it on and check.
If still no good connect a system speaker (example only) to the Power LED and Speaker Header pins as shown on p.28 of the user manual and check if there are any beep error codes heard. (see image below)
(click on image)
Was dit antwoord nuttig?
Voeg je antwoord toe
robert pickell zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 32
Altijd: 7,516
