Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
20-inch, 23-inch en 30-inch aluminium lcd-beeldschermen geïntroduceerd door Apple in juni 2004. Modellen respectievelijk A1081, A1082 en A1083.
Adding a Fuse to Protect Display
The Apple power supply finally bit the dust, it was used on my 30" Cinema Display. I have purchased one of the $20 240 Watt, 10 Amp power supplies to replace it. I would feel much more comfortable using this inexpensive PSU if I could add protection between the display and the power supply. I welcome any advice on how to add a fuse with the goal of not destroying the display should the power supply go haywire.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
@charles218 lets see what the end connectors look like. You can always add a 25 V 8 A inline fast-blow fuse.
Was dit antwoord nuttig?
6 opmerkingen:
I am planning on removing the connector from the dead Apple power supply and using it with the new power supply, this way I don't have to cut the display cable. It looks like the fuse would need to go between the recycled connector and the power supply tap.
door Deel
@charles218 yup. Right one the power lead.
door Deel
Is it important that the fuse holders wire be the same gauge or close to the same gauge as the connection wire?
door Deel
@charles218 not on that length. You'll be fine with slightly smaller/bigger leads.
door Deel
Old Turkey, you have been very helpful, thanks! I searched for the past half hour or so for 25 V - 8 Amps without success, nothing comes close, so if you or anyone has any leads on where I can find it, please let me know.
door Deel
1 commentaar meer tonen
Voeg je antwoord toe
Charles Larkins zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 505
