Ga door naar hoofdinhoud
48” diagonal Samsung LED flat screen tv with colored vertical lines.
Why is my screen blackout
Why is my tv screen blackout
Is dit een goede vraag?
Score 1
1 Opmerking:
@jurassic does it still have sound? What exact model is it? What have you checked? What exactly does it do?
door
Voeg een opmerking toe
1 Antwoord
@jurassic verify that you have no image on all inputs. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, use a flashlight and angle it against the screen with the TV at a station where you can hear the sound See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back. then visually check the boards for any obvious damage like domed or leaking capacitors. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Voeg afbeeldingen toe aan een bestaande vraag for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
Depending on what model your Samsung is, you can check the backlight by disconnecting the main board from the power board and then plugging it in. That should turn the backlights on. You can see that through the little holes in the back metal shield of the panel. Give us more information about what you got going on here.
Was dit antwoord nuttig?
Voeg je antwoord toe
Owen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 339
