Ga door naar hoofdinhoud
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
368 Vragen Bekijk alle
Connecting as external monitor to windows laptop
So. ill try to make this as clear as possible. I have a imac a1312, with set password, I cant get into it, but i dont actually need , because i just want to use it as external monitor. I've tried to connect it to my windows desktop pc with mini displayport>displaypor cable, and it works without issues. i just connect it, and imac shows image right away. Now my needs changed a little of bit, and i want to connect imac as external monitor to windows laptop (win10 or win11) , i have several of them. So i bought Mini displayport>HDMI cable (because all my laptops doesnt have displayport slot), and once i connect cable to laptop. nothing. FN F2 or other combinations doesnt work. i tried same cable with my desktop, and it doesnt work too. I tried tons of adapters ,still no success. i tried all my cables to another devices , just to be sure all of them is working. so it seems, imac accepts only mini dp>dp cable? hard to believe that any tips or suggestions?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Apple assumed people would use a Mac not a windows system. Even still a windows system which offered a miniDP could leverage it. The problem is an HDMI or other interface don’t carry the needed signals to do it.
Here’s some useful info:
Was dit antwoord nuttig?
Tomas Vonsavicius just turn your iMac into an external monitor. Use something like this guide How to turn a iMac Intel into an External Monitor - iFixit Repair Guide Even this answer SOLVED: How to turn an iMac 27 " 2010 Display into an external Monitor - iMac Intel 27" EMC 2390 - iFixit will help you out with it. All you essentially need will be LED driver boards and a power board like this Not very complicated but rewarding when done.
Voeg je antwoord toe
Tomas Vonsavicius zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 44
